#1
Oct 18, 2004
i am looking into getting a 52 mm crank to put into my 50 but i wanted to do some research first. so i went online looking for onee and all i could find is the fast 50's one. i was wondering if anyone knew of any other companys that made one? or mabe a 54mm thanx
#3
Oct 18, 2004
if i get that 54 mm what cc will it make my bike and will i need a heavy duty clutch and oil cooler and thats it or will i need more stuff. if i need more stuff like what?
thanx for the help :idea:
#6
Oct 18, 2004
yeah it is a 88cc with trail bikes head... get on aim or im me fmxrider09 talk there/..
#7
Oct 18, 2004
Remember, you have to purchase the correct piston with the stroker crank.
I would run the Kitiaco 51mm stroker crank, with Kitaco stroker piston and a 24-26mm carb which will bring your bike over 10HP at 108cc's.
Crank + Piston over $400
If you are set on a 110, get the Dratv.com 52mm stroker crank and their matching piston
Crank+ Piston under $300
Your choice.
#8
Oct 18, 2004
52mm are pretty much history for a good while till they get a new manufacturer from what I heard
#9
Oct 18, 2004
he is most likely goin with Dr atv crank and piston, he just needs to call them and see what s up with the cranks
#10
Oct 18, 2004
#11
Oct 18, 2004
KAOS said:
[quote name='mxracer728']he is most likely goin with Dr atv crank and piston, he just needs to call them and see what s up with the cranks
52mm are pretty much history for a good while till they get a new manufacturer from what I heard[/quote]i read that, I'm just telling you what he said
#12
Oct 18, 2004
Just order the following from Sik50's...
309-1083500 Kitaco Stroker Crankshaft
350-1083411 Kitaco Stroker Piston Kit - 12 V
#13
Oct 18, 2004
Ya Dratv is out of them with no ETA. BBR says they cant get them anymore and everyone else that was selling them says the same thing.
#14
Oct 18, 2004
what size stroker crank is that z88r? 51mm, 52mm? And how much is it from Sik50s
#15
Oct 18, 2004
It's a 51mm stroker crank. No idea how much Sik50's charges, as I purchased them out of Japan. Since you don't have resources in Japan, call sik50's..
#16
Oct 18, 2004
yeah, its for future references, no need for it at this time
#17
Oct 19, 2004
z88 is special he gets um Direct from Japland i mean Japan. yeah i will look into a 51 and see how that goes.. thanx for the info where can i find the Kitaco one?? *link*
#18
Oct 19, 2004
z88r gave you the parts numbers to order it from Sik50s.
#19
Oct 19, 2004
oh i was just wondering if they had picture of it and mabe a price
#21
Oct 19, 2004
alright i will tomarrow.. this is exciting now i can say my bike is the fastest outa all my friends haha
