Hey All!! Back in 2020, during Covid, I picked up a like new '21 KLX140R for a good price. It hadn't had more than a half tank of gas run through it by the guy's daughter. I haven't had the time to monkey with it... until now that is. I'm staying mostly stock mod with this build, as it's basically taking the place of my 110. I like riding mid sized bikes better than 110's. You get so much more for the money with the bigger bikes, and they're fun and easy to ride. My game plan for this project are as follows:
-Engine: Showroom stock. UNI air filter. Stock carb jetted at 42/100. Snorkel removed from the air box. Access block to carb air screw will be removed, allowing for adjustments via the D socket tool from Motion Pro. The baffle will be removed from the stock pipe.
-Frame: Will get beefed up at the known weak areas, then sent to powdercoat in the stock color. Likely a Ricochet skid plate will be added.
-Suspension: Bruce's Suspension will do damping rod mods to the front forks (stock springs). The back will get a KLX140G rear shock.
-Plastic and graphics: Stock plastics with 2015 OEM graphics. Bikegraphix number plate backgrounds. UFO "restyled" front fender cut to fit.
-Controls: Stock other than Pro Taper RM85 bars with an inch cut off both sides. They're almost a perfect match to the stock bars.
-Wheels: Black Tusk rims with Bridgestone Intermediate terrain tires. 52 tooth rear sprocket.
That's about it for now. I'll post up as I make progress. Stay tuned. --L*64
