1 - 8 of 8 Posts
Hey, I’ve recently put the tusk cold jet kit in my 110 To see if it would give any more performance along with my exhaust and it seems too rich. the only mods I’m running performance wise is a pro circuit t6. Do y’all have any recommendations on what jets to run, im contemplating doing the BBR u-flow intake to try to even it up, Or even see if the paranah upgraded coil Would help burn some more of the fuel. For now I’m going to put the stock jets back in. Any recommendations or advice would help greatly, thanks.
The dont believe much in the coil stuff, unless its altering the ignition timing, its only igniting a tiny amount of atomized fuel. You could try some of the airbox mods if you havent already, that would free it up and lean it out.
Doing the airbox mod and drilling out the stock headpipe I gained about 15-20% across the board. Re-jetting is required. That's on a 2020. I can tell you what jetting I am running but it's with a mod airbox.
what did you end up going with for jetting on these 2 mods ? i cant get mine right … thanks
1 - 8 of 8 Posts
