1 - 1 of 1 Posts
Check to make sure the oil is new and that it is properly full. Use 10w-40 non syntethic.
Check to also make sure that your air filter is breathing properly and isnt too oiled/dirty.
Also, are you sure that your carb is clean and isn't running to rich or lean. That happened to me and the bike ran like shit.
I also recommend a 22 mm Mikuni carb from TBOLT USA , but the stock one should work if its properly running.
One last thing I can think of off the bat is to check the spark plug wire and make sure its sparking. The spark plug could also be failing if its not made for the pit bike.
Let us know, thanks.
1 - 1 of 1 Posts
