1 - 8 of 8 Posts
I have a stock 110 engine and carb with the following mods:
• Pro Circuit T-4 system
• Removed air box snorkel
• UNI filter
• Shimmed Needle with Radio Shack #4 washer
• 40 Pilot jet
• 85 Main jet
• Turned in Air screw ¼ turn (assuming this make it richer)
• Bumped up idle (would stumble and die when warm/cold)
• TB Manual clutch
Still have some bog and stumble on the bottom but seems to run good on mid and top without any stumbles or bog. Things I will not do are adding pod filter because of mud and frequent cleaning or add a big bore kit. Just want to get rid of the stumble on the bottom. Any suggestions would be great. Thanks
1 - 8 of 8 Posts
