My son found this bike, could someone explain the ignition system to me. 3 wires coming from stator, 1 black to ignition coil 2 white just cut off.
1. No spark, only getting 5 volts AC from the black wire that feeds ignition coil while spinning engine with a drill at 1500rpm. On DC it shows - 0.4.
2. The other 2 white wires I assume are for the charging coil, do they have any impact on ignition?
3. next to the flywheel is a little brass spring loaded wire connector, what is its purpose?
Looks like previous owner soldered in a new condenser but no idea if it is any good . Am i right in thinking the stator coil supplys AC voltage through the condenser and points then to ignition coil.
Thanks for any help
Thanks for any help
