1 - 7 of 7 Posts
Alright all. I've got a new build coming on. Today, I finished my engine. Here are the specs. Anyone have an estimate on the HP for something like this one?
155cc build from Base RCM engine
56mm bore x 63mm stroke
Akunar high dome piston, machined custom
Akunar +6mm stroke kit fitted to a GPX crankshaft
Zongshen BVH fully ported
Custom ground camshaft (mimics closely the Z40 but a little less lift)
Takegawa 28mm intake
Mikuni TM28 flatslide
Yoshimura Dax pipe
Flywheel and Oil Sling shaved
All this will be mounted to a 1975 Honda CT70 in metalic sparkly green. The build of the bike starts right after my kitchen is in and will be documented in the Vintage Honda section. But since I had a china engine for it, here we go.
1 - 7 of 7 Posts
