need a shift shaft for 2004 klx 110.
edgeridercr15 said:stock or aftermarket. I have a stock one.
edgeridercr15 said:Yeah, I am pretty sure I have one of those. It was a stock one removed for a chp short shift shaft. Teeth are fine on it.
underestimated said:If i'm not mistaking you can use a newer year model also, you just have to get a new shifter. The shaft that sit's on the oil seal is the same size it's just the spline that shifter sit's on are different.
