| | #1 (permalink) |
| 1st Gear Member Join Date: Sep 2008 Location: Gilbert AZ
| i didnt know if it was working our not so i put clear hoses on just to see if it was pumping oil and its not. any ideas anyone, here are some pics ![]() ![]() |
| | #2 (permalink) |
| 2nd Gear Member Join Date: Dec 2006 Location: Greensboro, NC
| Re: kitaco oil cooler help! To find out if it is working, run the engine and touch the oil cooler, if it is hot, it's working, if not start looking for the clog.... Last edited by bat999; 10-05-2008 at 06:32 PM. Reason: spelling |
| | #3 (permalink) |
| Re: kitaco oil cooler help! i put clear lines on it so i could see if the oil was atleast going into the oil cooler and got nothin. any one else got any ideas? |
| | #4 (permalink) |
| 1st Gear Member Join Date: Jul 2008
| Re: kitaco oil cooler help! well you have a clog somewhere or your oil pump isnt working, do you have a hv pump on it? |
| | #5 (permalink) |
| Re: kitaco oil cooler help! how would i check for a clog anywhere? no i dont |
| | #6 (permalink) |
| Sporting the Merkin Join Date: Mar 2004 Location: boston area
| Re: kitaco oil cooler help! Did you have oil pressure getting to the head before you installed the cooler ?
__________________ The older I get...The faster I was !!! |
| | #7 (permalink) |
| Re: kitaco oil cooler help! yeah |
| | #8 (permalink) |
| Re: kitaco oil cooler help! take the cooler off, put some rubbing alcohol in one side and see if it comes out the other or use can use compressed air, just turn down your regulator if its set high. |
| | #9 (permalink) |
| Re: kitaco oil cooler help! You better take off that head plate then and make sure the gasket isnt blocking the passageway or something goofy. Try blowing through one fitting and see if it flows through the cooler.
| | #10 (permalink) |
| Re: kitaco oil cooler help! ill try all these today after school, thanks for the help. ill keep you updated |
| | #11 (permalink) |
| Re: kitaco oil cooler help! okay here is the update, if i lean my bike over it will get oil in the line then eventually it will start pumping it by itself, does this mean i need a high volume oil pump or something? |
| | #12 (permalink) |
| Re: kitaco oil cooler help! either that or your oil level is really low |
| | #13 (permalink) |
| Re: kitaco oil cooler help! no its not low i filled it up to the recomended level, do you think my oil pump could be bad, the only thing stock on the whole bike is the transmission and its an 03 xr 50 |
| | #14 (permalink) |
| Re: kitaco oil cooler help! okay so i thought my oil pump was bad so i took off my entire right side apart and something is missing inside of the oil pump, so i need to just order a new one. life sucks but here is the tear down and ignore the red tires there for street use to destroy instead of my nice dunlops. im also thinking about selling the frame soon its a red baron factory G2 frame ![]() ![]() ![]() |
| | #15 (permalink) |
| 3rd Gear Member Join Date: Nov 2003 Location: Connecticut .. Where big bikes are for kids . :)
| Re: kitaco oil cooler help! Those pics really suck !! But I'm guess'n someone forgot to put on the cover plate for the oil pump ?? If that is what was the issue ? Idk how the impeller stay in place ? |
| | #16 (permalink) |
| Re: kitaco oil cooler help! cell phone pics, we all know how they are. no i did that to see inside of it, how does the impeller stay in place anyways, it didnt have andthing to hold it on |
| | #17 (permalink) |
| Re: kitaco oil cooler help! That plate holds in place . I don't get it ..., what is missing then ? |
| | #18 (permalink) |
| Re: kitaco oil cooler help! i dont know but it will not hold the impeller in place at all, even with cover on. |
| Bookmarks |
| Tags |
| cooler, help!, kitaco |
| Thread Tools | |
