Go Back   Planet Minis > Forum > General Talk > CRF50
Old 10-05-2008, 05:43 PM   #1 (permalink)
1st Gear Member
MiniRacer959's Avatar
Question kitaco oil cooler help!
i didnt know if it was working our not so i put clear hoses on just to see if it was pumping oil and its not. any ideas anyone, here are some pics
MiniRacer959 is offline   Reply With Quote
Old 10-05-2008, 06:32 PM   #2 (permalink)
2nd Gear Member
bat999's Avatar
Re: kitaco oil cooler help!
To find out if it is working, run the engine and touch the oil cooler, if it is hot, it's working, if not start looking for the clog....
bat999 is offline   Reply With Quote
Old 10-05-2008, 09:43 PM   #3 (permalink)
1st Gear Member
i put clear lines on it so i could see if the oil was atleast going into the oil cooler and got nothin. any one else got any ideas?
Old 10-05-2008, 10:13 PM   #4 (permalink)
1st Gear Member
well you have a clog somewhere or your oil pump isnt working, do you have a hv pump on it?
loopedout is offline   Reply With Quote
Old 10-05-2008, 11:11 PM   #5 (permalink)
1st Gear Member
how would i check for a clog anywhere? no i dont
Old 10-05-2008, 11:28 PM   #6 (permalink)
Sporting the Merkin
FastMC's Avatar
Awards Showcase
FOTM Award
Total Awards: 1
Did you have oil pressure getting to the head before you installed the cooler ?
__________________
The older I get...The faster I was !!!
FastMC is offline   Reply With Quote
Old 10-05-2008, 11:32 PM   #7 (permalink)
1st Gear Member
yeah
Old 10-05-2008, 11:37 PM   #8 (permalink)
1st Gear Member
take the cooler off, put some rubbing alcohol in one side and see if it comes out the other or use can use compressed air, just turn down your regulator if its set high.
Old 10-05-2008, 11:38 PM   #9 (permalink)
Sporting the Merkin
FastMC's Avatar
Awards Showcase
FOTM Award
Total Awards: 1
You better take off that head plate then and make sure the gasket isnt blocking the passageway or something goofy. Try blowing through one fitting and see if it flows through the cooler.
__________________
Old 10-06-2008, 07:50 AM   #10 (permalink)
1st Gear Member
ill try all these today after school, thanks for the help. ill keep you updated
Old 10-06-2008, 04:17 PM   #11 (permalink)
1st Gear Member
okay here is the update, if i lean my bike over it will get oil in the line then eventually it will start pumping it by itself, does this mean i need a high volume oil pump or something?
Old 10-06-2008, 06:43 PM   #12 (permalink)
1st Gear Member
either that or your oil level is really low
Old 10-06-2008, 06:48 PM   #13 (permalink)
1st Gear Member
no its not low i filled it up to the recomended level, do you think my oil pump could be bad, the only thing stock on the whole bike is the transmission and its an 03 xr 50
Old 10-06-2008, 10:46 PM   #14 (permalink)
1st Gear Member
okay so i thought my oil pump was bad so i took off my entire right side apart and something is missing inside of the oil pump, so i need to just order a new one. life sucks but here is the tear down and ignore the red tires there for street use to destroy instead of my nice dunlops. im also thinking about selling the frame soon its a red baron factory G2 frame
Old 10-07-2008, 07:10 PM   #15 (permalink)
3rd Gear Member
JohnnyB's Avatar
Location: Connecticut .. Where big bikes are for kids . :)
Those pics really suck !!
But I'm guess'n someone forgot to put on the cover plate for the oil pump ??
If that is what was the issue ? Idk how the impeller stay in place ?
JohnnyB is offline   Reply With Quote
Old 10-07-2008, 07:19 PM   #16 (permalink)
1st Gear Member
cell phone pics, we all know how they are. no i did that to see inside of it, how does the impeller stay in place anyways, it didnt have andthing to hold it on
Old 10-07-2008, 08:00 PM   #17 (permalink)
3rd Gear Member
JohnnyB's Avatar
That plate holds in place .
I don't get it ..., what is missing then ?
Old 10-08-2008, 09:25 PM   #18 (permalink)
1st Gear Member
i dont know but it will not hold the impeller in place at all, even with cover on.
Old 10-09-2008, 04:22 AM   #19 (permalink)
3rd Gear Member
JohnnyB's Avatar
This is your oil pump .
What parts are you missing from this pic ?
Old 10-09-2008, 04:06 PM   #20 (permalink)
1st Gear Member
i dont know i havent taken that cover off on the top yet, i will when i get home.
cooler, help!, kitaco
Page generated in 0.17258 seconds with 13 queries
