Go Back   Planet Minis > Forum > General Talk > CRF50
Old 10-06-2008, 07:56 PM   #1 (permalink)
1st Gear Member
MoTo_XXX's Avatar
clutch,oil pump,carby/bore kit questions...???
hi lads
will a GENUINE PC18 carb work on a TB 88 race head kit or is it to small will i need a 20,22 or somthing or are the shengway carbs that come with that kit ok??? or would the PC18 be better???
also i got a TB heavy duty billter clutch and a TB hi volume oil pump now i wanted to know since ill have all the clutch out and that can i just put the oil pump on while im putting the new clutch in so cna i just run it with the stock engine untill i get my bore kit??? or cant i use the hi vol oil pump with a stock engine???
thanks in advance
MoTo_XXX is offline   Reply With Quote
Old 10-06-2008, 08:09 PM   #2 (permalink)
"ZBBT"
BlackBeard's Avatar
Re: clutch,oil pump,carby/bore kit questions...???
you need to take the top end off to drill out the passageway to 2mm. also i would atleast get a 20 or 22mm for that kit
BlackBeard is offline   Reply With Quote
Old 10-06-2008, 08:15 PM   #3 (permalink)
1st Gear Member
MoTo_XXX's Avatar
thanks mate
but is it ok to use the hi vol oil pump with stock engine??? just for a couple months???
carby/bore, clutch, oil, pump, questions...???
Page generated in 0.10410 seconds with 13 queries
