| | #1 (permalink) |
| 3rd Gear Member Join Date: Feb 2007 Location: Houston, TX
| kx65 with a yz250 motor Is it possible? I found a kx65 roller for pretty cheap, and i have a yz250 motor. i was thinking about buying the yz250 motor mounts, and modding them to this frame. is that at all possible or is it way too big? i was even going to cut off the bottom part of the frame and weld it to the kx65 frame that way there is little modding left to do because it will be a bolt up deal. what do you guys think? |
| | #2 (permalink) |
| 3rd Gear Member Join Date: Jun 2008 Location: Glendale California
| Re: kx65 with a yz250 motor Its possible...It would be a pretty gnarly ride but definately doable...I've seen 250s stuffed into 85s/150Rs and a kx500 motor in a kx 85 chassis... |
| | #3 (permalink) |
| Re: kx65 with a yz250 motor im sure it would be a f'in ripper hahaha just wondering if its possible. |
| | #4 (permalink) |
| 3rd Gear Member Join Date: Dec 2006 Location: Austin, Texas
| Re: kx65 with a yz250 motor Small gas tank, big pipe. |
| | #5 (permalink) |
| Re: kx65 with a yz250 motor As long as the engine dont burn the gas tank... ![]() |
| | #6 (permalink) |
| Re: kx65 with a yz250 motor |
| | #7 (permalink) |
| 3rd Gear Member Join Date: Sep 2006 Location: Riverside, CA
| Re: kx65 with a yz250 motor bank on cutting up the entire frame and doing it all custom. anything is possible but it won't be a weld a tab here and a spacer here kind of thing for sure. |
| | #8 (permalink) |
| | #9 (permalink) |
| 3rd Gear Member Join Date: Oct 2006 Location: Scottsdale, AZ
| Re: kx65 with a yz250 motor hahah do ittt this would be soo rad. Talk about a squirl though jesus.... |
| | #10 (permalink) |
| Chuck Norris for president! Join Date: Nov 2007 Location: Boyne City Michigan
| Re: kx65 with a yz250 motor deff go for it, this winter im doin an 85/250 conversion hopefully |
| | #11 (permalink) |
| Re: kx65 with a yz250 motor oh im sure we will have to extend it and raise the tank, seat, and everything else a couple inches. but if we get a frame from a yz250 and cut the bottom half off, and weld it to the bottom of the kx65 frame, it should be nearly done... |
| | #12 (permalink) |
| | #13 (permalink) |
| Re: kx65 with a yz250 motor ahhh cheater!!!!!!!! |
| | #14 (permalink) |
| Re: kx65 with a yz250 motor or just say youve never ridden a 65 and race it in novice |
| | #15 (permalink) |
| Re: kx65 with a yz250 motor Make sure to run a couple rim locks on the back. :P It will be one custom bike thats for sure. |
| | #16 (permalink) |
| Re: kx65 with a yz250 motor You might wanna run stiffer springs front and rear...Or go with a whole different suspension setup all together... |
| | #17 (permalink) |
| Re: kx65 with a yz250 motor yeah ill have the stiffest suspension available for this...im gonna try and get an elka for the rear, if they dont make one, i may get elka to mod me one... |
| | #18 (permalink) |
| Re: kx65 with a yz250 motor ohlins makes a great shock if you got the money |
| | #19 (permalink) |
| Re: kx65 with a yz250 motor You should post a picture of the roller an the motor sitting next to each other. |
| | #20 (permalink) |
| Re: kx65 with a yz250 motor money is not an issue. its gonna be me and my buddys bike. so 2 peoples income, should be just fine haha but its gonna be sick, no doubt! i think im gonna do it. me and my buddy have set out to do it hahaha |
| Bookmarks |
| Tags |
| kx65, motor, yz250 |
| Thread Tools | |
