Go Back   Planet Minis > Forum > General Talk > Roost Area
Old 08-30-2008, 06:42 PM   #1 (permalink)
2nd Gear Member
iskatealot33's Avatar
Awards Showcase
FOTM Award FOTM Award
Total Awards: 2
kx250f problem, please help!!!
so my bike runs good for about 2 or 3 laps then just suddenly bogs and dies, or will just die without bogging. Once this happens it will die like every 3 minutes. i will be either on the gas or just letting off into a corner or something and it will just bog/die. It will start up again right after a few kicks and idle good, rev good, and all. It is really annoying and unsafe because i dont want it to die right before a lip and cause me to endo etc...so i need to fix this asap. Any ideas what is wrong?
Any help is greatly appreciated, thanks
iskatealot33 is offline   Reply With Quote
Old 08-30-2008, 06:51 PM   #2 (permalink)
3rd Gear Member
JohnnyB's Avatar
Location: Connecticut .. Where big bikes are for kids . :)
Re: kx250f problem, please help!!!
How old is the plug ?
Maybe you have a wire in the electrical system that is chaffed and grounding out cause'n the bike to die ?
JohnnyB is offline   Reply With Quote
Old 08-30-2008, 06:54 PM   #3 (permalink)
2nd Gear Member
Awards Showcase
Total Awards: 2
JUST changed the spark plug, i thought that was the problem but it is not.
and ill check out the electrical, thanks
Old 08-30-2008, 06:57 PM   #4 (permalink)
2nd Gear Member
Motoknuckle's Avatar
Definetly sounds like an electrical issue.
Run through some checks and tell us what you find.
Motoknuckle is offline   Reply With Quote
Old 08-30-2008, 07:05 PM   #5 (permalink)
1st Gear Member
carey's Avatar
Shoulda bought a Honda
carey is offline   Reply With Quote
Old 08-30-2008, 07:06 PM   #6 (permalink)
2nd Gear Member
Awards Showcase
Total Awards: 2
Quote:
no thanks
Old 08-30-2008, 07:16 PM   #7 (permalink)
3rd Gear Member
SUZUKIRM12594's Avatar
It could be something stupid like the gas swtich is off, or the choke is on...If not, clogged jets and or the electircals (specifically coils) can be the issue...Defenately sounds the same as wut happened to my stupid ass, Running with the gas closed and dying on every corner and bogging sick...ahahaha its probably not though
SUZUKIRM12594 is offline   Reply With Quote
Old 08-30-2008, 07:26 PM   #8 (permalink)
2nd Gear Member
Awards Showcase
Total Awards: 2
Quote:
haha i checked the gas and choke probably a hundred times
its definatly not that
im pretty sure its the electrical, im gonna go check it out soon
Old 08-30-2008, 07:56 PM   #9 (permalink)
3rd Gear Member
Pimpindahoes's Avatar
Awards Showcase
FOTM Award
Total Awards: 1
bad coil. replace and your golden.
it will eventually go out 100%
Pimpindahoes is offline   Reply With Quote
Old 08-30-2008, 07:57 PM   #10 (permalink)
"ZBBT"
BlackBeard's Avatar
if not electrical sounds like dirt in the carb, the particle gets sucked up clogging the jet and restricting gas flow, once it dies the suction stops and you can get gas again only until that piece gets sucked up again.
BlackBeard is offline   Reply With Quote
Old 08-30-2008, 07:59 PM   #11 (permalink)
2nd Gear Member
Quote:
Hmm, very good idea. Try cleaning your float bowl, jets, etc. See if you find anything.
Old 08-30-2008, 07:59 PM   #12 (permalink)
3rd Gear Member
Awards Showcase
FOTM Award
Total Awards: 1
its a possibility but probably not the case here.
would be smart to clean out the crab before you spend any money though.
Old 08-30-2008, 08:16 PM   #13 (permalink)
3rd Gear Member
Quote:
Originally Posted by iskatealot33 View Post
no thanks
yup kawi 250f's are way better .
on topic check your ground wire first ,a rusted ground mount drove me crazy for a few hours .
DEMONDAVE is offline   Reply With Quote
Old 08-30-2008, 08:22 PM   #14 (permalink)
1st Gear Member
gncc_jake's Avatar
check your ground...sounds like a loose ground to me or like ZBBT said, foreign object in the carb...possibly your pet-cock is broken and restricting fuel flow to a trickle
gncc_jake is offline   Reply With Quote
Old 08-30-2008, 08:31 PM   #15 (permalink)
1st Gear Member
gncc_jake's Avatar
also check that your tank vent hose is not clogged...could be gettin vapor lock and slowly letting air back in, enough to get goin again, and lock again
Old 08-30-2008, 08:36 PM   #16 (permalink)
3rd Gear Member
Shoulda bought a Suzuki
Quote:
yup Suzuki RMZ250s are way better
Old 08-30-2008, 08:40 PM   #17 (permalink)
2nd Gear Member
slayer66's Avatar
Awards Showcase
FOTM Award
Total Awards: 1
tank vent...that is what got mc hurt on the ktm
slayer66 is offline   Reply With Quote
Old 08-30-2008, 08:41 PM   #18 (permalink)
2nd Gear Member
I really hope you're kidding.
Old 08-30-2008, 08:44 PM   #19 (permalink)
3rd Gear Member
JohnnyB's Avatar
Quote:
Good one bro ! I forgot about that one ..
Also check the cap !
Old 08-30-2008, 08:46 PM   #20 (permalink)
3rd Gear Member
Quote:
YA...I was being sarcastic. I dont really have anything against any bike except for maybe KTM for not using a linkage.
help!!!, kx250f, problem
Page generated in 0.25201 seconds with 13 queries
