Go Back   Planet Minis > Forum > General Talk > Roost Area
Old 08-06-2008, 07:14 PM   #1 (permalink)
3rd Gear Member
xr100man's Avatar
2 stroke engine question please look
I HAVE A QUICK QUESTION. I AM IN THE PROCESS OF PUTTING IN NEW RINGS IN A 1979 RM 125. I'M JUST WONDERING I CHANGED THE TRANS OIL ON THE BIKE TODAY WITH RED HONDA TRANS OIL. IM JUST WONDERING WHEN I WAS LOOKING AT THE CRANK IT IS FULL OF THE NEW RED TRANS OIL. IS THAT NORMAL? I PUT THE CYLINDER BACK ON AND THE PISTON IS NOT DRAGGING ANY TRANS OIL UP. JUST WONDERING IF THIS IS NORMAL FOR THE TRANS OIL TO BE ON THE CRANK OR IF THERE IS A PROBLEM. ANY INPUT WOULD BE APPRECIATED. THANKS
xr100man is offline   Reply With Quote
Old 08-06-2008, 07:20 PM   #2 (permalink)
3rd Gear Member
firepower354's Avatar
Re: 2 stroke engine question please look
Sounds like bad crank seal, or center case gasket. Not surprising, given it's age. Cheap and easy to replace.
Sweet old scoot. I'd almost forgot about the funky "N" model fenders. Looks like the front got swapped for a later one? I had a 78 with the cobbled looking aluminum banana arm.
Old 08-06-2008, 07:23 PM   #3 (permalink)
3rd Gear Member
xr1million's Avatar
Yea, you have either a bowl right crank seal, leak between center cases or a hole in the cases into the crank area!
xr1million is offline   Reply With Quote
Old 08-06-2008, 07:52 PM   #4 (permalink)
3rd Gear Member
xr100man's Avatar
Can I run it like this?
Old 08-06-2008, 07:57 PM   #5 (permalink)
3rd Gear Member
SUZUKIRM12594's Avatar
Quote:
Maybe for a while if you run engine oil in the tranny but I REALLY DO NOT RECOMMEND IT!!!
SUZUKIRM12594 is offline   Reply With Quote
Old 08-06-2008, 08:02 PM   #6 (permalink)
3rd Gear Member
50-50's Avatar
They're right - it's probably a crank seal. If you're smart you won't run it like this because you'll fix it while you have it apart. You can wait for a $2.00 part and put it in now or you'll have to tear down the whole engine again just to put this $2.00 part in. Think it through. It's not a hard choice.
50-50 is offline   Reply With Quote
Old 08-06-2008, 08:03 PM   #7 (permalink)
3rd Gear Member
xr100man's Avatar
Is it that hard do i have to split the cases? So it is suppose to be dry on the crank?
Old 08-07-2008, 06:18 AM   #8 (permalink)
3rd Gear Member
xr100man's Avatar
Any more opinions?
Old 08-07-2008, 06:37 AM   #9 (permalink)
Advertiser
TheCRKid's Avatar
Any more opinions?
opinions ?
you never have tranny oil in the crank case on a 2 stroke
period
pull the motor
replace the crank seals and center case gaskets
no choice
__________________
T Bolt USA
Website
TheCRKid is offline   Reply With Quote
Old 08-07-2008, 07:35 AM   #10 (permalink)
3rd Gear Member
xr100man's Avatar
How hard is that to do? Do I have to take out the transmission gear by gear?
Old 08-07-2008, 08:09 AM   #11 (permalink)
1st Gear Member
This site may give you an idea of what's involved. New Page 1 There are sections on splitting and assembling the case. If you leave it like that, it'll run rich and foul plugs.
BTW. look at this Mini. He ain't the mad scientist for nothing.
stevec is offline   Reply With Quote
Old 08-07-2008, 03:36 PM   #12 (permalink)
3rd Gear Member
xr100man's Avatar
I hope that I can just get away with crank seals how hard are those?
Old 08-07-2008, 05:00 PM   #13 (permalink)
3rd Gear Member
xr1million's Avatar
I doubt its the crank seal because they usually only leak when the engine is running or when you pressure test the bottom end. (if you can find a way to seal the ports then you can pressure check it at no more than 6 PSI)
If I were you I would buy a manual and pull the whole thing apart! The worst part on bottom ends is the tranny, but if your careful to not let the gears fall off the shafts then you wont have a problem with it.
Also tranny fluid will cause scuffing between the piston and cyl. ... dont know why, as oil is a lubricant and the tranny oil is oil.
ANd that little mini bike with the 80 motor is bad ass!!!!!
Old 08-07-2008, 06:04 PM   #14 (permalink)
2nd Gear Member
firepower like this one? it's a 78 1/2 C2
keith42 is offline   Reply With Quote
Old 08-07-2008, 06:06 PM   #15 (permalink)
2nd Gear Member
No throw some seals in it and you'll be good to go.
Old 08-07-2008, 07:43 PM   #16 (permalink)
3rd Gear Member
Quote:
Yup. There was no C2 125 or 400, though. The 250 C came out early with a steel arm and aluminum tank, and the 125/400 were intro'd at the regular time with the 250 C2 plastic tank and alloy arm. If my memory serves me better than some of my other functions
Good call on the rerouted resivour lines. Mine wore in to my boots before I figured how to run them different. I was 12, so improvements came in small steps.
Dig the 81 YZ80 too! I was on a 465 by then, but little bro had one I'd steal for a few laps. I'd tell him we'd swap, kill the 465 with the choke and roost off on his, while his 115lbs tried to start the flooded big bore. He'd have killed himself if it ever fired up.
Old 08-07-2008, 07:57 PM   #17 (permalink)
2nd Gear Member
your correct, Suzuki only had this swingarm and plastic style for 1 year. I had a 1980 RM400 back in 80. in my profile I have pictures of my 79 yz80 and my MR50's.
Old 08-07-2008, 08:06 PM   #18 (permalink)
3rd Gear Member
Sweet rides, too!
Old 08-07-2008, 08:46 PM   #19 (permalink)
Advertiser
TheCRKid's Avatar
1978 1/2 RM 250 C-2
my first real MX bike !!
__________________
T Bolt USA
Website
Old 08-07-2008, 08:49 PM   #20 (permalink)
2nd Gear Member
CJsDad's Avatar
Are you sure its trans fluid? Is the oil you mix in the gas red? It could be the oil from your gas. Usually a crank seal on the clutch side will smoke real bad and when you change the clutch oil, there will be a lot missing.
CJsDad is offline   Reply With Quote
engine, question, stroke
Page generated in 0.19647 seconds with 13 queries
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40
