| | #1 (permalink) |
| 3rd Gear Member Join Date: Feb 2007 Location: Chicago Burbs
| 2 stroke engine question please look I HAVE A QUICK QUESTION. I AM IN THE PROCESS OF PUTTING IN NEW RINGS IN A 1979 RM 125. I'M JUST WONDERING I CHANGED THE TRANS OIL ON THE BIKE TODAY WITH RED HONDA TRANS OIL. IM JUST WONDERING WHEN I WAS LOOKING AT THE CRANK IT IS FULL OF THE NEW RED TRANS OIL. IS THAT NORMAL? I PUT THE CYLINDER BACK ON AND THE PISTON IS NOT DRAGGING ANY TRANS OIL UP. JUST WONDERING IF THIS IS NORMAL FOR THE TRANS OIL TO BE ON THE CRANK OR IF THERE IS A PROBLEM. ANY INPUT WOULD BE APPRECIATED. THANKS ![]() ![]() ![]() |
| | #2 (permalink) |
| 3rd Gear Member Join Date: Oct 2006 Location: Flint MI
| Re: 2 stroke engine question please look Sounds like bad crank seal, or center case gasket. Not surprising, given it's age. Cheap and easy to replace. Sweet old scoot. I'd almost forgot about the funky "N" model fenders. Looks like the front got swapped for a later one? I had a 78 with the cobbled looking aluminum banana arm. |
| | #3 (permalink) |
| 3rd Gear Member Join Date: Dec 2005 Location: Just south of hell, FL
| Re: 2 stroke engine question please look Yea, you have either a bowl right crank seal, leak between center cases or a hole in the cases into the crank area! |
| | #4 (permalink) |
| Re: 2 stroke engine question please look Can I run it like this? |
| | #5 (permalink) |
| 3rd Gear Member Join Date: Jun 2008 Location: Glendale California
| Re: 2 stroke engine question please look |
| | #6 (permalink) |
| 3rd Gear Member Join Date: Aug 2006 Location: PA
| Re: 2 stroke engine question please look They're right - it's probably a crank seal. If you're smart you won't run it like this because you'll fix it while you have it apart. You can wait for a $2.00 part and put it in now or you'll have to tear down the whole engine again just to put this $2.00 part in. Think it through. It's not a hard choice. |
| | #7 (permalink) |
| Re: 2 stroke engine question please look Is it that hard do i have to split the cases? So it is suppose to be dry on the crank? |
| | #8 (permalink) |
| Re: 2 stroke engine question please look Any more opinions? |
| | #9 (permalink) |
| Advertiser Join Date: Jan 2005
| Re: 2 stroke engine question please look opinions ? you never have tranny oil in the crank case on a 2 stroke period pull the motor replace the crank seals and center case gaskets no choice
__________________ T Bolt USA ALL top Pitbikes ,Engines and Parts for Pitbikes & Minis Website Contact THECRKID@TBOLTUSA.COM or Call 215-630-3554 |
| | #10 (permalink) |
| Re: 2 stroke engine question please look How hard is that to do? Do I have to take out the transmission gear by gear? |
| | #11 (permalink) |
| 1st Gear Member Join Date: Sep 2007
| Re: 2 stroke engine question please look This site may give you an idea of what's involved. New Page 1 There are sections on splitting and assembling the case. If you leave it like that, it'll run rich and foul plugs. BTW. look at this Mini. He ain't the mad scientist for nothing. index.gif ![]() |
| | #12 (permalink) |
| Re: 2 stroke engine question please look I hope that I can just get away with crank seals how hard are those? |
| | #13 (permalink) |
| Re: 2 stroke engine question please look I doubt its the crank seal because they usually only leak when the engine is running or when you pressure test the bottom end. (if you can find a way to seal the ports then you can pressure check it at no more than 6 PSI) If I were you I would buy a manual and pull the whole thing apart! The worst part on bottom ends is the tranny, but if your careful to not let the gears fall off the shafts then you wont have a problem with it. Also tranny fluid will cause scuffing between the piston and cyl. ... dont know why, as oil is a lubricant and the tranny oil is oil. ANd that little mini bike with the 80 motor is bad ass!!!!! |
| | #14 (permalink) |
| 2nd Gear Member Join Date: Nov 2007 Location: sumner, wa
| Re: 2 stroke engine question please look firepower like this one? it's a 78 1/2 C2 ![]() |
| | #15 (permalink) |
| | #16 (permalink) |
| Re: 2 stroke engine question please look Yup. There was no C2 125 or 400, though. The 250 C came out early with a steel arm and aluminum tank, and the 125/400 were intro'd at the regular time with the 250 C2 plastic tank and alloy arm. If my memory serves me better than some of my other functions Good call on the rerouted resivour lines. Mine wore in to my boots before I figured how to run them different. I was 12, so improvements came in small steps. Dig the 81 YZ80 too! I was on a 465 by then, but little bro had one I'd steal for a few laps. I'd tell him we'd swap, kill the 465 with the choke and roost off on his, while his 115lbs tried to start the flooded big bore. He'd have killed himself if it ever fired up. |
| | #17 (permalink) |
| Re: 2 stroke engine question please look your correct, Suzuki only had this swingarm and plastic style for 1 year. I had a 1980 RM400 back in 80. in my profile I have pictures of my 79 yz80 and my MR50's. |
| | #18 (permalink) |
| Re: 2 stroke engine question please look Sweet rides, too! |
| | #19 (permalink) |
| Re: 2 stroke engine question please look 1978 1/2 RM 250 C-2 my first real MX bike !!
| | #20 (permalink) |
| 2nd Gear Member Join Date: Jan 2007 Location: BrookPark, Ohio
| Re: 2 stroke engine question please look Are you sure its trans fluid? Is the oil you mix in the gas red? It could be the oil from your gas. Usually a crank seal on the clutch side will smoke real bad and when you change the clutch oil, there will be a lot missing. |
| Bookmarks |
| Tags |
| engine, question, stroke |
| Thread Tools | |
