Go Back   Planet Minis > Forum > General Talk > Stunt Minis
Old 07-21-2007, 02:00 AM   #21 (permalink)
1st Gear Member
Re: CR85 Problems, won't run!
the reason you guys are fouling plugs is because of 3 things
1- you are running with to much oil in the gas (i have foung 32-1 to be the best and 35/40-1 for racing applications but that cuts the piston/rings life in half at best)
2-che carb is set to ritch letting to much fuel in the engine in any give rpm
3- you are riding like a girl and not hitting the powerband regularly witch burns off all excess fuel in the engine
also as stated before check the reeds
and worst comes to worst take it back to the dealer that did the top end and have them fix it (usually covered in the saisfaction guraentee, or atleast that is how the local suzuki/honda dealership is if they do any work and it is proven to be faulty within 10 days of picking up the bike they will repare it free of charge) also when they were working on it and had it torn apart thy should have inspected the reeds in witch case they should have written on the reciept that they are coming close to needing to be changed
stunt_squid is offline   Reply With Quote
Old 07-21-2007, 02:28 AM   #22 (permalink)
3rd Gear Member
RcWannabe's Avatar
Gleen hit it on the head, your plug is fouled. And cleaning them does not fix a fouled plug. When it fouls the core curns out so cleaning it is of no use
RcWannabe is offline   Reply With Quote
Old 07-21-2007, 02:30 AM   #23 (permalink)
3rd Gear Member
RcWannabe's Avatar
A cracked or broken reed can foul plugs as well
Old 07-21-2007, 03:53 AM   #24 (permalink)
1st Gear Member
Quote:
i understand i thought was understood previously?
i mean dosen't that fall under the category of " the dealer should have seen the reeds were either bad or getting bad thus should have made a side note on the recipt "
i was pointing out the less obvias reasons
oh and what was the temp when it was running? and what is the current temp?
if it is not colder then you need to ritchen the carb and if it is hoter you need to lean the carb, usually about 3/4 of a turn dose but some times require to move the clip one space
Old 08-20-2007, 12:39 PM   #25 (permalink)
2nd Gear Member
Thumpin90's Avatar
i bet the plug is fouled. i had the same problem with my 85. i poped a new plug in a fired right up. im almost finished with my xr70/cr80 conversion. the front wheels wont stay down,
Thumpin90 is offline   Reply With Quote
Old 08-20-2007, 01:10 PM   #26 (permalink)
PM Newbie
i would say check the coil. i had a cr once that would start but as soon as one tryed to take off and rev the think is would splutter and die. the coil was partly damaged so still sparked but couldnt tell the diference betwwen a proper spark this damaged spark. check with a multimeter and test the resistance on the coils
umka is offline   Reply With Quote
Old 08-20-2007, 02:34 PM   #27 (permalink)
2nd Gear Member
lol. this thread is from back in february....i'm guessing he's got it fixed by now
trizzbizzle is offline   Reply With Quote
Page generated in 0.17641 seconds with 13 queries
