Go Back   Planet Minis > Forum > General Talk > Honda CRF70
Old 08-14-2008, 08:10 AM   #1 (permalink)
PM Newbie
VM26 carb problem
Hey, I have a 04 crf70 with 88cc big bore kit with race head and stroker kit installed, it rips above 1/4 throttle but runs rich at idle up to 1/4 throttle, I have the smallest pilot jet installed a 12.5, could the float height be to high causing a rich condition at idle, anybody have problems with the vm26 Mikuni carb. Help.
rough rider is offline   Reply With Quote
Old 08-14-2008, 09:14 AM   #2 (permalink)
2nd Gear Member
jRob409's Avatar
Re: VM26 carb problem
That carb is way to big for a 88 in my opinion. I run a 20mm on my TB88 racehaed.
jRob409 is offline   Reply With Quote
Old 08-14-2008, 09:30 AM   #3 (permalink)
PM Newbie
Well it's really a 108cc because of the stroker kit installed so it should handle a vm26 ok.
Old 08-14-2008, 11:23 AM   #4 (permalink)
2nd Gear Member
jRob409's Avatar
woops sorry I didnt see that until now that it was a strocker. I have a 24mm on my 108. Mine ran ok with the 26 when I put it on but it didnt have the throttle response that I wanted. If I remeber right I couldnt get the low end ot run right either. My advice would be a 24mm Kiehin and a diff intake manifold.
Old 08-14-2008, 11:38 AM   #5 (permalink)
PM Newbie
Yea I was afraid that carb might be to big but a lot of the kits come with that carb so I think I'll play with it a little longer, if worse come to worse I'll get the 24mm carb, Thanks.
Old 08-14-2008, 11:43 AM   #6 (permalink)
PM Newbie
Might need a smaller main. That jet effects 1/4 throttle a lill too
PrerunninF150 is offline   Reply With Quote
Old 08-14-2008, 02:38 PM   #7 (permalink)
2nd Gear Member
jRob409's Avatar
Quote:
Thats kinda what I thought when I put mine together. Cyclerider showed me the light and I am alot happier with my setup now.
carb, problem, vm26
Page generated in 0.15264 seconds with 13 queries
