Go Back   Planet Minis > Forum > General Talk > Honda CRF70
Old 07-25-2008, 08:48 PM   #1 (permalink)
1st Gear Member
mxracer49's Avatar
Need a couple stock XR70 parts
Was having problems with my kids' 70. I went ahead and tore it completely down tonight.
Ordering a new top end gasket kit, high volume oil pump, 52mm ring set (88 kit). Putting in new valve guides. Going to lap the valves also. Heavy cam chain and getting an aftermarket cam.
I need the 2 small 17mm bolt on valve covers. I haven't seen these on any of the sites except dratv but it says they are for 50s. I need a cam sprocket bolt also. I can probably get this at the hardware store but just in case. Haven't taken the flywheel off yet going to do that tomorrow. May as well go in there and see if anything shows signs of wear while I have the motor out.
So if anybody has any of these parts they want to get rid of let me know or turn me on to some online deals.
Thanks
Darin
mxracer49 is offline   Reply With Quote
Old 07-25-2008, 09:13 PM   #2 (permalink)
3rd Gear Member
firepower354's Avatar
Re: Need a couple stock XR70 parts
The new guides are likely to need to be reamed to size once installed, then the seats cut to match. I've seen several 70 heads with worn guides, but 50's seem to last forever Might be cheaper/easier to get a deal on a TB/E22/etc head???
70 pump is higher volume than the 50 pump. 50 covers and cam bolts are the same as 70's. Might want a cam chain, for peace of mind.
Old 07-25-2008, 10:31 PM   #3 (permalink)
1st Gear Member
mxracer49's Avatar
I'm confused. Are you saying the valve guides are not just a quick replacement part? I'd really like to stay with the stock 70 head and go with a larger cam. But if worst comes to worst I suppose I could just get an E22 from dratv for 88 bucks. Not real thrilled about that, though.
Then you say the 70 oil pump is higher volume than the 50 pump. Am I wasting my money buying a high volume pump? Should I just stay with the stock 70 pump with the 88kit?
Old 07-26-2008, 06:46 AM   #4 (permalink)
3rd Gear Member
Correct on the guides. Not a drive out-drive in deal. I really like the 70 head, once ported to remove the bowl machining steps and the runner pinch. Maybe the guides would be ok with new valves?
I feel the 70 pump is plenty, but it's not much money for a HV, and shouldn't hurt anything.
couple, parts, stock, xr70
Page generated in 0.15958 seconds with 13 queries
