| | #1 (permalink) |
| 1st Gear Member Join Date: Dec 2007 Location: canton ohio
| loose timing chain xr70 please help!! i have a xr70 with a loose timing chain could some one please call me and help me right quick 330 639 5157 it will be fine and then when the piston comes around the chain loosens. |
| | #2 (permalink) |
| 3rd Gear Member Join Date: Oct 2006 Location: Flint MI
| Re: loose timing chain xr70 please help!! Running? It will fill with oil on it's own, but you can lay it on the right side and fill the oil cavity through the 6mm hole/10mm head below the stator cover. |
| | #3 (permalink) |
| PM Newbie Join Date: Feb 2005 Location: Bloomington, IL
| Re: loose timing chain xr70 please help!! Did something happen to the tensioner? |
| | #4 (permalink) |
| Re: loose timing chain xr70 please help!! not that i know of why? |
| | #5 (permalink) |
| Re: loose timing chain xr70 please help!! I can't think of any other reason it would go loose, unless it was extremely worn out. Or maybe if something happened to the plastic roller in the side of the cylinder. |
| | #6 (permalink) |
| Re: loose timing chain xr70 please help!! like it is tight then like it gets looser as it cranks then gets tight and keeps doin it. |
| | #7 (permalink) |
| Re: loose timing chain xr70 please help!! This is in a previously smooth running engine? Nothing new done, it just started slapping? |
| | #8 (permalink) |
| Re: loose timing chain xr70 please help!! it ran perfect ttok the top end off to check the rings and ever since it has been doin it wont even start now. |
| | #9 (permalink) |
| Re: loose timing chain xr70 please help!! I'd pull the ignition to verify everything's working and in the right spot. You tried filling the tensioner through the side hole using an oilcan? Sure the cam timing's right? |
| | #10 (permalink) |
| 1st Gear Member Join Date: Oct 2007 Location: Kansas
| Re: loose timing chain xr70 please help!! Did you resolve this? If so, how? My kids bike is doing the same exact thing. |
| Bookmarks |
| Thread Tools | |
