Go Back   Planet Minis > Forum > General Talk > Honda CRF70
Old 07-03-2007, 09:42 PM   #1 (permalink)
PM Newbie
Help with stock 70 motor tune.
I added a pipe and UNI filter to my stock 70. I have adjusted the needle clip to every position so far with the same results. It runs best in the second position from the bottom. But in every position I have a very small hesitation when you crack the throttle from idle. If you crack it from any other position other than idle it rips. It just has a slight hesitation off idle(very slight). Messed with fuel screw and idle in every position. I think the main may need to be changed from stock. It sounds like it is starving for gas with almost a sucking noise. Is this the main? 88 kit is coming but my son is going to ride this weekend so I need to figure it out. Thanks in advance..
43XR70 is offline   Reply With Quote
Old 07-03-2007, 09:54 PM   #2 (permalink)
Baron Von BanHammer
Kurlon's Avatar
Re: Help with stock 70 motor tune.
Put the stock pipe back on and see how it responds. You may wanna just bump the idle up a bit also. Until that motor is massaged a bit, it won't have perfect throttle response.
__________________
http://www.x386.net/TTR
2004 ST3 - 'Duckie'?!?!
2005 CRF70RR - MiniGP Weapon
2005 CRF70 - Dirt Donk
2008 Pitster Pro X4 Motard
1991 GS500E - LRRS/CCS #771
Kurlon is offline   Reply With Quote
Old 07-03-2007, 10:17 PM   #3 (permalink)
1st Gear Member
steely66's Avatar
dude on your carb where the fuel pipe goes onto the carb fuel cock ok clean inside that with a small pin or fuse wire and blow all the **** out of it ive had this problem many times i tryed rejeting needle height the lot turned out it was the fuel cock blocked.
steely66 is offline   Reply With Quote
Old 07-19-2008, 09:09 PM   #4 (permalink)
PM Newbie
spiralsun1's Avatar
OMG, that might be the problem I'm having too... TYVM
spiralsun1 is offline   Reply With Quote
Old 08-18-2008, 08:27 PM   #5 (permalink)
2nd Gear Member
fiddyonefiddy's Avatar
probably since you are letting in twice as much air you should allow twice as much fuel
try jetting the carb if you cant fix it by raising the needle.and it will always hesitate,till you dial it in.
fiddyonefiddy is offline   Reply With Quote
Page generated in 0.13846 seconds with 13 queries
