Go Back   Planet Minis > Forum > General Talk > Honda CRF70
Old 07-25-2008, 06:57 AM   #1 (permalink)
1st Gear Member
mxracer49's Avatar
Cam Chain Problem
Reposted with correct heading.
02 XR70 with 88kit with what I think is a stretched cam chain. It has gotten extremely noisy the past few times out. I took off the cam chain cover on the head last night and rotated the flywheel while watching the chain. It has a "catch" in it. Hard to explain but it will stay tight until you rotate past TDC then the chain becomes very loose to the point of dragging on the cylinder. I took out the back tensioner and reinstalled several times with no help. Does the piston have to be in a certain position when putting the tensioner back in?
It died last night and wouldn't resart. Finally got it started and thought I needed to adjust the valves again. Did that and it still wouldn't start. That's when I started digging a little deeper.
I'm starting to wonder if the timing is 180 out on this thing.
Thanks all
Darin
mxracer49 is offline   Reply With Quote
Old 07-25-2008, 05:46 PM   #2 (permalink)
2nd Gear Member
bat999's Avatar
Re: Cam Chain Problem
Thanks all
Darin
If it was out 180 it would not run.....
bat999 is offline   Reply With Quote
Old 07-30-2008, 07:49 AM   #3 (permalink)
1st Gear Member
mxracer49's Avatar
Old chain was stretched beyond belief. I ordered a new one and actually thought they sent the wrong size. Until I counted the links.
Old 07-30-2008, 08:35 AM   #4 (permalink)
1st Gear Member
76CR125ME's Avatar
thanks for the follow up post...
Im doing a build on a motor that
has the same symptom...
THANKS
76CR125ME is offline   Reply With Quote
chain, problem
Page generated in 0.14633 seconds with 13 queries
