Go Back   Planet Minis > Forum > General Talk > Honda CRF150R And CRF150F
Old 02-18-2008, 01:01 AM   #1 (permalink)
"ZBBT"
BlackBeard's Avatar
Talking crf150f engine swap info
just figured id do a little tech talk. the crf230 and 150 f's if you dont know share common motor mounting points as the xr200 enigines. you need to elongate and drill a hole or to but its pretty much bolt and go, for you people looking to have the ultimate pitbike heres what i run. rare but find a 1986-1987(only made two years) honda reflex TLR 200. they use a sweet motor. crank mounted ignition instead of cam and the killer part is there close ratio 6 speed motors! same top end as 200's so bore em out. i might but my engine up for sale later for the right price but its a 220 now with custom ground DMC cam and DMC ported and polished head. pushing 13:1 compression it sits on my garage floor as i snapped the kicker shaft. Go out and build those 150's!!
BlackBeard is offline   Reply With Quote
Old 02-19-2008, 12:10 PM   #2 (permalink)
3rd Gear Member
firepower354's Avatar
Re: crf150f engine swap info
Did the Reflex have a bigger fin head and jug like 200X's?
firepower354 is online now   Reply With Quote
Old 02-19-2008, 12:47 PM   #3 (permalink)
Kurlon's Avatar
How big physically is the bottom end on the TLR200?
__________________
http://www.x386.net/TTR
2004 ST3 - 'Duckie'?!?!
2005 CRF70RR - MiniGP Weapon
2005 CRF70 - Dirt Donk
2008 Pitster Pro X4 Motard
1991 GS500E - LRRS/CCS #771
Kurlon is offline   Reply With Quote
Old 02-19-2008, 03:24 PM   #4 (permalink)
"ZBBT"
BlackBeard's Avatar
mounts the same the cases are much more compact. I will take pics and measurments tomorrow but its a great little motor
Old 02-19-2008, 09:41 PM   #5 (permalink)
Kurlon's Avatar
Quote:
If you can get a comparison against an XR80/100 motor, or 50 motor, that'd be cool... : )
__________________
Old 02-19-2008, 10:08 PM   #6 (permalink)
"ZBBT"
BlackBeard's Avatar
yes, i will do a side by side to a 100 motor i have pulled out. my 50 motor is still bolted to my bike but i will prop it up to the bike. by far its the best honda motor i feel for any build. i found a whole complete reflex at a local garage sale for 150 dollars
Old 02-20-2008, 09:41 PM   #7 (permalink)
3rd Gear Member
Not so sure on the gearing...
Vins Bike Page, formally '2strokes.html'
Page generated in 0.15829 seconds with 13 queries
