Go Back   Planet Minis > Forum > General Talk > 1988 ZB50 and ZB Import Replica Bikes
Old 05-14-2008, 08:34 AM   #1 (permalink)
3rd Gear Member
fatcaaat's Avatar
Max sustainable speed: 85, 88, 95cc?
Well, it seems no one has the bank for my ST90 and it is such a shame to have it sit here in the garage.
So, I am going to take the 153cc Jialing motor out of it and pop one in of standard configuration (with a 49cc stamped cylinder). This way it can be used as a scooter in VA without tagging it.
So, this bike is pretty light and its been a good while since we've talked about the smaller motors.
What do you think is a good cruising speed to aim for with the following motor sizes? Also, maybe some help with gearing to achieve this?
70cc
88cc
95cc
108cc (stroker)
My guesses?
70cc - 40
88cc - 45
95cc - 50
108cc - 55 (stroker)
fatcaaat is offline   Reply With Quote
Old 05-14-2008, 10:32 AM   #2 (permalink)
3rd Gear Member
firepower354's Avatar
Re: Max sustainable speed: 85, 88, 95cc?
Sounds accurate.
Old 05-14-2008, 11:31 AM   #3 (permalink)
2nd Gear Member
fastbmw's Avatar
pretty bang on. My 88cc does about 47-ish
fastbmw is offline   Reply With Quote
Old 05-14-2008, 02:22 PM   #4 (permalink)
2nd Gear Member
shawnbassett26's Avatar
chriswilders, zb50 with a stroker 100, weve got up 70MPH 15t/35t
~Shawn
shawnbassett26 is offline   Reply With Quote
Old 05-14-2008, 02:26 PM   #5 (permalink)
3rd Gear Member
RcWannabe's Avatar
I think a stock 70cc engine would be more comfortable in the 35 range, you might get 40 but the tall gearing might make it not so fun to get going.
RcWannabe is offline   Reply With Quote
Old 05-14-2008, 02:29 PM   #6 (permalink)
3rd Gear Member
Stock? Hah!
Old 05-14-2008, 02:39 PM   #7 (permalink)
3rd Gear Member
50rider340's Avatar
i got a c70 with just a pod filter and a homade pipe that really flows (i grinded off the 72ccs so i dont have to worry about tags here in CT either. On the flats with my skinny ass on it (130lbs) i get 40 all the time down hill i tach the speedo out at 55. Keep in mind the larger wheels prolly help out alot for my speeds. It is a 3 speed n up hills i get 30-35 depending on steep it is.
What tranny would you plan on useing the stock 3 speed?
Tagless bikes are where its at right now. 60+mpg with gas at 4 bucks i ride it everywhere
Id stick with the 88cc mark. That way you dont burn up to much fuel.
50rider340 is offline   Reply With Quote
Old 05-14-2008, 03:13 PM   #8 (permalink)
2nd Gear Member
1TrikZB's Avatar
Awards Showcase
FOTM Award
Total Awards: 1
My 1968 Honda CT90 maintained 57 mph GPS confirmed. I have a stock exhaust, but a tweeked carb and points setup.
1TrikZB is offline   Reply With Quote
Old 05-14-2008, 03:28 PM   #9 (permalink)
3rd Gear Member
fatcaaat's Avatar
Well, what I am going for here is what type of speed should i expect without the worry of the motor coming apart. Certainly I can't run a motor like this at 10k for 30 minutes straight. So, it is ok to expect to run it at 7k? Could I go 55-60 mph at 7k on a 108cc motor in this bike or is it more reasonable to go 45-50?
Top speed not really a concern...max sustainable where we don't have to worry about the motor coming apart is what I'm after.
Old 05-14-2008, 03:40 PM   #10 (permalink)
3rd Gear Member
RcWannabe's Avatar
Quote:
Exactly, that is my train of thought behind my other response. 7 thousand rpm would be a good cruising speed I think. If I was to build a street bike I would definetly go for the stroker crank so I could run the tall gear but still have some get up and go. With the 108 I think you could get 50+ mph without too many r's.
Old 05-15-2008, 06:31 AM   #11 (permalink)
1st Gear Member
damageinc2785's Avatar
do they really look at the cc's on the engine?
i've never had anyone look at that, just whats on the title/reg.
damageinc2785 is offline   Reply With Quote
Old 05-15-2008, 08:18 AM   #12 (permalink)
3rd Gear Member
fatcaaat's Avatar
in VA you don't require title/reg for a scooter. in VA it is 49cc that qualifies as a scooter that doesn't need reg/title/license...or inspection.
Old 05-15-2008, 10:18 AM   #13 (permalink)
1st Gear Member
here in ny you have to register and inspect and insure it if its over like 25mph i think
but you can drive it with a permit i think.
Page generated in 0.20393 seconds with 14 queries
