Go Back   Planet Minis > Forum > General Talk > Chinese/Import Minis - General Discussion
Old 09-02-2008, 08:33 AM   #1 (permalink)
PM Newbie
jjpluml's Avatar
Carb problems
ok so my little bro broke his throttle cable on his orion and i got a new one and slapped it on and now his bikes acting up hardcore. The bike will start and run with the choke on but when you turn the choke off it backfires through the carb and pops and then eventuallt dies. The bikes also smoking white in a bad way!!! tried adjusting the needle up to the middle clip but not any better. The plug is soaking wet when i pull it out also so i dunno wtf... HELP!!
jjpluml is offline   Reply With Quote
Old 09-02-2008, 08:47 AM   #2 (permalink)
2nd Gear Member
onlydirt's Avatar
Re: Carb problems
Tare down the carb, clean it out, make sure the float isnt sticking. Makes sure the throttle cable is long enough, so its not pulling the carb open at all. Re set your idel screw.
onlydirt is offline   Reply With Quote
Old 09-02-2008, 09:02 AM   #3 (permalink)
PM Newbie
jjpluml's Avatar
Re: Carb problems
where should the idle screw be setting? I mdae sure that the needle was closing all the way, u think the float could do this?
Old 09-02-2008, 09:24 AM   #4 (permalink)
1st Gear Member
lemmonbomb's Avatar
Re: Carb problems
make sure the carb is clean and that the throttle cable has enough travel.
lemmonbomb is offline   Reply With Quote
Old 09-02-2008, 10:03 AM   #5 (permalink)
2nd Gear Member
onlydirt's Avatar
Re: Carb problems
I had a bad float on an OKO and it did as you described.
Old 09-02-2008, 10:09 AM   #6 (permalink)
PM Newbie
jjpluml's Avatar
Re: Carb problems
the needle defanitly sets all the way down n the carb. No question. ive just never heard of a float makin a bike run like this
carb, problems
Page generated in 0.13801 seconds with 13 queries
