Go Back   Planet Minis > Forum > General Talk > KLX110, DRZ110, TTR90
Old 08-14-2008, 08:38 AM   #1 (permalink)
PM Newbie
brake problem
i took my back wheel off an tryed to put it back on and now the wheel wont ever turn, it sounds like something with the brakes
bdub622 is offline   Reply With Quote
Old 08-14-2008, 08:48 AM   #2 (permalink)
2nd Gear Member
Luckystar64's Avatar
Re: brake problem
I'd almost guarantee that either you have to loosen the wing nut on the back of the brake rod, OR! You forgot to put that spacer in that goes between the brake panel, and the rear hub. I've done that before, and more than a few of my friends have done it before too.
When I did it, I mistook the part for a piece that went with the centrifugal clutch-- haha. My mechanic was working on the clutch while I was putting a Supercomp on the back. The spacer was sitting around, but I didn't recall it coming from the rear wheel. I just assumed it was from the clutch. Live and learn. --L*64
Luckystar64 is offline   Reply With Quote
brake, problem
Page generated in 0.11646 seconds with 13 queries
