Go Back   Planet Minis > Forum > General Talk > KLX110, DRZ110, TTR90
Old 08-05-2008, 09:09 AM   #1 (permalink)
1st Gear Member
Bore/head question?
Can i run the MotoHP 150 kit with the v2 head and a stroker crank? Or is the piston not right for the head?
LineMaker881 is offline   Reply With Quote
Old 08-05-2008, 09:13 AM   #2 (permalink)
1st Gear Member
Re: Bore/head question?
And it says you do not need to bore the cases, so does that make it a scut or not because thats what i really want to avoid
Old 08-05-2008, 12:13 PM   #3 (permalink)
2nd Gear Member
mtbracer's Avatar
The kit does not need case boring and it's not the "scout" design piston.
mtbracer is offline   Reply With Quote
Old 08-05-2008, 03:37 PM   #4 (permalink)
1st Gear Member
Will i be able to run that with the v2 and the 55mm crank? If so is this a good way to go, because i would like to just go full out v2 stroker (not scut) but im kind of a little nervous to bore the cases seeing that you could never go smaller again.
Old 08-05-2008, 05:11 PM   #5 (permalink)
2nd Gear Member
the 150 alone doesnt need boring but im pretty sure you have to bore the cases when you do a stroker with it..and it will work with that head
bonez1093 is offline   Reply With Quote
Old 08-05-2008, 05:54 PM   #6 (permalink)
3rd Gear Member
2wheeltyson's Avatar
it depends how old the 150 kit is. mine would not clear the v2 or +R heads bt the new ones will. and if you bore your cases you can always go back smaller without any problems.
2wheeltyson is offline   Reply With Quote
Old 08-05-2008, 06:41 PM   #7 (permalink)
2nd Gear Member
mtbracer's Avatar
no boring required with a stoker 5mm
Old 08-06-2008, 08:11 AM   #8 (permalink)
1st Gear Member
slide1in's Avatar
I run this setup, no boring, you might have to run a race gas mix. Also i run a pe28mm, it rips.
slide1in is offline   Reply With Quote
Old 08-07-2008, 12:11 AM   #9 (permalink)
1st Gear Member
i dopnt know i just cracked my cases recently and i just threw a cat 5 on to stop it from going furthur. But i think i might just go with the complete v2 160 kit and get new prebored cases from pax for 100 bucks.
bore/head, question?
Page generated in 0.14949 seconds with 13 queries
