Go Back   Planet Minis > Forum > General Talk > KLX110, DRZ110, TTR90
Old 09-05-2008, 04:05 PM   #1 (permalink)
PM Newbie
4th gear shift drum? and cam?
how hard to install these ??
trdboy2485 is offline   Reply With Quote
Old 09-05-2008, 04:15 PM   #2 (permalink)
PM Newbie
HALL39's Avatar
Re: 4th gear shift drum? and cam?
have to split the cases. so not a 5 min job. cam you will have to take the top end apart.
HALL39 is offline   Reply With Quote
Old 09-05-2008, 05:29 PM   #3 (permalink)
Moderator
geof's Avatar
Quote:
to fit the shift drum means a full strip down - so allow about 5 hours
Have a look here for cam fitting instructions - takes about 30 minutes to 1 hour:
http://www.twobros.com/Cust_Service/...8-045_Inst.pdf
geof is offline   Reply With Quote
Old 09-05-2008, 05:32 PM   #4 (permalink)
1st Gear Member
the cam is easy you dont need to take the head off a 110 its a quick job but you have to split the cases for a 4th gear
kman153 is offline   Reply With Quote
Old 09-06-2008, 08:50 AM   #5 (permalink)
PM Newbie
UpOn2PassingYou's Avatar
How hard? Not hard for either. The shift drum can be done within about 3-5 hours depending on how many times you have stripped a jap small motorcycle engine apart.
UpOn2PassingYou is offline   Reply With Quote
cam?, drum?, gear, shift
Page generated in 0.10804 seconds with 13 queries
