Go Back   Planet Minis > Forum > General Talk > KLX110, DRZ110, TTR90
Old 05-12-2008, 11:09 PM   #1 (permalink)
PM Newbie
143kit stock head, pipe & carb - what's next as I expected more.
Just put in a 143 kit. I have the stock head (opened up the exhast port) and the stock pipe (opened up the header restriction and rear baffle but kept the end nipple tube on) I'm running the stock carb and a 95 main. It only has less than 10 minutes on it so the rings have not fully seated yet and it seems a bit rich (a little boggy and the plug confirms it)
I had my CRF70 (88 bore and 110 stroker, & pipe) side by side taking turns and the CRF seems faster still. I want to look at the jetting and give it more time on the break in but I'm still expecting more as it sits when comapared to a bike with 33 less cc's ?
What is the estimated power? How much more will an aftermarket pipe do over the stock modded pipe? I don't want to really invest in a carb and/or head but if so what order and power per dollar is the best?
Landrew is offline   Reply With Quote
Old 05-13-2008, 12:02 AM   #2 (permalink)
2nd Gear Member
bonos110's Avatar
Re: 143kit stock head, pipe & carb - what's next as I expected more.
get a cam and a 26mm carb, and some better exhaust, but yes a jetting problem could really be holding it back
bonos110 is offline   Reply With Quote
Old 05-13-2008, 12:31 AM   #3 (permalink)
2nd Gear Member
50s_rock's Avatar
Aftermarket exhaust will be alot better then stock modded. Get a pipe and carb. If you really want some power, the Trailbikes V2 race head too.
50s_rock is offline   Reply With Quote
Old 05-13-2008, 06:07 AM   #4 (permalink)
PM Newbie
Sorry, it did come with a cam.
Old 05-13-2008, 06:48 AM   #5 (permalink)
1st Gear Member
mo' tarded's Avatar
The stock carb size is holding you way back. The engine is starving.
mo' tarded is offline   Reply With Quote
Old 05-13-2008, 07:03 AM   #6 (permalink)
2nd Gear Member
Catlin G's Avatar
Quote:
w3rd
Catlin G is offline   Reply With Quote
Old 05-13-2008, 03:16 PM   #7 (permalink)
3rd Gear Member
coletrain01's Avatar
stock pipe is slowing you down as well as the stock carb. get a 26mm carb and a race head and cam and you will gain alot
coletrain01 is offline   Reply With Quote
Old 05-13-2008, 03:18 PM   #8 (permalink)
3rd Gear Member
xulcuz's Avatar
I would get a pipe and carb if I were you....
xulcuz is offline   Reply With Quote
Old 05-13-2008, 06:21 PM   #9 (permalink)
PM Newbie
bbrklx110's Avatar
I would get and exhaust, carb and get a tb race head.It would be a lot faster than the setup you have now!!!
bbrklx110 is offline   Reply With Quote
Old 05-13-2008, 08:31 PM   #10 (permalink)
3rd Gear Member
dood's Avatar
194
dood is offline   Reply With Quote
Old 05-13-2008, 09:03 PM   #11 (permalink)
2nd Gear Member
bonos110's Avatar
hell put a 250f motor in it.....
Page generated in 0.13059 seconds with 13 queries
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39
