Go Back   Planet Minis > Forum > General Talk > KLX110, DRZ110, TTR90
Old 08-27-2008, 08:22 PM   #1 (permalink)
PM Newbie
08 ttr 110 needs parts help
Recently I bought a new 08 TTR 110 and I know its a new bike but I am trying to find aftermarket parts! Can anyone point me in the right direction!
ttr110ridin is offline   Reply With Quote
Old 08-27-2008, 09:20 PM   #2 (permalink)
2nd Gear Member
ekripper's Avatar
Re: 08 ttr 110 needs parts help
GYTR parts on yamaha's web site. You can do carb, cam, hd peg mount, pegs, tall seat, bar kit, pipe, hd springs fr. and rear, air filter and jet kits. Other pipe options are Two bros, and FMF 4.1. Pax can get you excel rims for it as well. Hopefully someday a bore kit will be available. I've heard rumors of one from Yamaha and Powroll has a 124 kit listed on their site that still isn't available yet. You can also put a fox air shock on the rear. You need to have the 3/4" extension to make it the same length as the stocker though. KLX one is a bit to short. I'm running one on mine and it works great. That's about it as far as I know.
ekripper is offline   Reply With Quote
Old 08-27-2008, 09:30 PM   #3 (permalink)
2nd Gear Member
Kawirider359's Avatar
I have actually seen someone with a TTR110 and zokes on here, so do a little searching.
Kawirider359 is offline   Reply With Quote
Old 08-27-2008, 09:50 PM   #4 (permalink)
3rd Gear Member
SUZUKIRM12594's Avatar
Quote:
and a mono swinger...Pax had one with zokes but used an a-frame. But some other dude had zokes and a mono
SUZUKIRM12594 is offline   Reply With Quote
Old 08-27-2008, 09:56 PM   #5 (permalink)
2nd Gear Member
ekripper's Avatar
Pax can get you zokes that fit and you can just pick a swingarm and do some fab work to get the shock mounted. Really needs more motor before this is really necessary. You can also get the manual clutch and primary gear from Yamaha too...forgot about that.
Old 08-27-2008, 09:58 PM   #6 (permalink)
3rd Gear Member
That would be sick if someone mounted a modded out KLX engine on the TTR.
Old 08-27-2008, 10:05 PM   #7 (permalink)
2nd Gear Member
Yeah but that kind of takes half the fun out of having a TTR and being different than everyone else, and isn't stock to stock klx vs ttr the ttr has more hp or something. I love how they look when I saw that one with zokes and swinger and stuff.
Old 08-28-2008, 06:13 AM   #8 (permalink)
PM Newbie
also for pipe, I have a pro circuit t-4 and its awsome, I think its the best looking pipe out for the ttr 110, sounds great too. I have the gytr clutch kit and that works great. Been riding mine all summer, no problems with it.
EKripper, I'm thinking about getting the fox shock, right now I have the gytr rear spring but I still bottom out. How does the fox shock compare to the rear with gytr spring? So a fox klx shock with a 3/4in. extension puts the rear at stock ride height?
I cant see putting a china swinger on, but thats just me.
RacerScott is offline   Reply With Quote
Old 08-28-2008, 06:56 AM   #9 (permalink)
PM Newbie
EKripper, I checked out your bike, nice blue bling. I see you put a chain roller on, did that help with chain slap, what brand wheel is it? I come into corners hard with mine and I can hear the chain slapping.
Old 08-28-2008, 02:41 PM   #10 (permalink)
2nd Gear Member
ekripper's Avatar
Quote:
Chain roller helped alot with the chain slap! My wheels are excels that I got from Pax.
Old 08-28-2008, 02:43 PM   #11 (permalink)
2nd Gear Member
ekripper's Avatar
The Fox shock makes a huge difference! I put the HD spring on at first and it still really sucked. You just get a KLX 110 shock and they have different lenght extensions that thread on to the end of the shaft to make it the correct lenght. 3/4" put it pretty close to the stock eye to eye length. I had the Fox rep make me one up at mini moto this year and just love it. You gain about an inch more travel as well and the ride height stays the same.
Old 08-28-2008, 03:27 PM   #12 (permalink)
1st Gear Member
Vegaskid199's Avatar
pics of it with the pipe
Vegaskid199 is offline   Reply With Quote
Old 08-28-2008, 03:38 PM   #13 (permalink)
2nd Gear Member
Js789's Avatar
get a crf 70 shock from fox it is a little longer than one for a klx
Js789 is offline   Reply With Quote
Old 08-28-2008, 04:08 PM   #14 (permalink)
PM Newbie
Quote:
check my album
ekripper, what brand, model chain roller did you use, just any klx one will work???
Old 08-29-2008, 08:24 AM   #15 (permalink)
2nd Gear Member
ekripper's Avatar
check my album
Yep, just anything for the KLX and there is plenty of room on the frame to drill the hole.
Old 09-03-2008, 07:00 PM   #16 (permalink)
1st Gear Member
bump
Old 09-03-2008, 07:04 PM   #17 (permalink)
3rd Gear Member
507 brett's Avatar
talk to ttr110pilot. guys a ttr genious
507 brett is offline   Reply With Quote
parts
Page generated in 0.15693 seconds with 13 queries
