| | #1 (permalink) |
| Baron Von BanHammer Join Date: Feb 2005 Location: Windham, ME
| S90 parts Ok, so I'm drifting a bit outside the forum scope, but figured this is the best spot to get Z's attention. : ) Got a friend looking to hop up his S90. Powroll and Dr ATV both offer 54mm bore kits, Powroll offers a crank stroking service for the bike. Do any of the JDM brands offer hop ups for that motor?
__________________ http://www.x386.net/TTR 2004 ST3 - 'Duckie'?!?! 2005 CRF70RR - MiniGP Weapon 2005 CRF70 - Dirt Donk 2008 Pitster Pro X4 Motard 1991 GS500E - LRRS/CCS #771 |
| | #2 (permalink) |
| 3rd Gear Member Join Date: Sep 2004 Location: Arlington, VA
| Re: S90 parts Honda ATC125M from 84 and 85 crankshaft is 52.2mm I believe and will drop in (so I heard). |
| | #3 (permalink) | |
| 5th Gear Member Join Date: Sep 2003 Location: KANSAS
| Re: S90 parts Quote:
There is no aftermarket part support in Japan for the CT90, ST90 or S90 that I'm aware of. Boat anchors. If you want to build up a boat anchor, fatcaaat is your man. | |
| | #4 (permalink) | |
And since they are different mountwise, you'll have to fabricate stuf to make a 70 base or china base work. So, unless you are interested in a lot of fab work, I'd say ditch the bike. If you want that style, find a CL70 to work with. The forks and springs and things....I have no clue on. I'd avoid it personally...its going to be a headache. Put it to stock, sell it, and then buy a vintage CL70. | |
| | #5 (permalink) |
| Re: S90 parts Take the S90 engine out and build one of these: CUSTOM HONDA I can't tell is that's a CT90 or a 50/70 based engine. Too bad nobody in their right mind would by that thing. It took some talent to build, but what's the point? Dan |
| | #6 (permalink) |
| Re: S90 parts The owner uses it for vintage racing, mostly Giros on public roads, so I doubt I can convince him to move to something else, or swap in a modern engine. He was just looking for a bit more power for a couple of the mountain passes he was running up. He's also got an S65 he's running as well.
| | #7 (permalink) |
| Re: S90 parts Now an S65...that can be made into a really fun machine. I did one a while back and when completed was a whole bunch of fun. I used modern forks and shocks, and a 95cc motor. The s90 if you want more power, you can do the following; Cam...send the cam out to webcamshafts.com and have them hardweld a new grind on it. The number 3 won't work, but the one just below it will. Carb...of course you can update the carb. Those vintage carbs are crappy compared to modern stuff. I personally like the mikunis. Porting...send it out to be done correct. I am sure you know who they are. Bore/Stroke. Again, pretty sure the atc125m crank will swap in. Pin relocation and welding is a lot of money but not a bad option. Bore...If I am not mistaken, the atc125m cylinder will fit on there as well...don't quote me on that. I have a cylinder and varous head components for one here if you want them. Dratv used to have a 3mm bore kit for it but I think it uses a 15mm pin and therefore can run the atc125m set. I have to believe that without some serious work, you won't pull more than 10hp. |
| Bookmarks |
| Tags |
| parts |
| Thread Tools | |
